Version 3.0.9.1549
Mono Version 6.12.0
OS: Linux
I understand this more a feature than a bug, but I want to turn it off.
An external Software adds a metadata folder with images related to an Episode. The rename feature works really well, except the images are renamed (good) and moved (problem). I found no issue on GitHub or in forum or setting to change the behavior.
It will apply to all seasons, even if I rename only a specific one.
Before rename
- Series
-- Season 1
--- metadata
-- NyanCat S01E01.mkv
After rename
- Series
-- Season 1
--- metadata (empty)
-- Nyan Cat S01E01 - 24h (BluRay 8k-HDR TrueHD).mkv
Is there any setting or alternative a post hook for a shell script?
