I'm experiencing an issue with input fields when accessing Sonarr from my iPad
2.0.0.4389
OS:
iOS 9.3.5
((Debug logs)):
Accessing Sonarr through Safari
In short, I cannot scroll in an input field to edit text if the text is longer than the input field itself.
The only way I can edit such fields is to tap-hold in between characters until I get the “Select All” option, then copy/paste the text into Notes, edit the text and copy/paste it then back to the input field.
In the case of setting op renaming patterns this means I also cannot use the auto-insertion of formatting elements without switching back and forth from/to Notes to construct a naming pattern.
Am I overlooking something?
