Sonarr Ver. 2.0.0.4472
Windows 10 - Anniversary Edition - 64 bit
Sonarr has recorded a program according to the minimum quality in the profile. I watch the program and delete it. Sonarr loads it again to replace the deleted version.
I found the switch labelled “Ignore Deleted Episodes”. The “?” indicates that “episodes deleted from disk are automatically unmonitored by Sonarr”.
Should this switch be on or off for deleted episodes to be unmonitored?
Is there a special way to delete the episodes or does any deletion work? (I typically delete from within Kodi after watching the episode.)
