IE 10 Not Compatable
A lot of the menus do not function in IE 10. Most importantly, the “save” button does not work. I had to install Chrome on my server to get Drone installed. I installed probably about 6 months ago, and it has not worked from day one. I was surprised since it is .Net based. It has not been a huge deal, but I did not see it reported anywhere else. I cannot access Drone from IE 10 on Server 2012 or IE 10 on Windows 8 Pro x64. Is this a known issue, or is there a security setting I need to change in IE ?
We are done rewriting NzbDrone from scratch, the new UI should be fully compatible with IE9 and IE10. its currently in private testing.
Let me know if you want to get early access, we would love to have someone with IE10 using the new version and reporting issues.
Here are some screenshots of the new version,
