iCal link does not work in gmail?
Sonarr version: 2.0.0.5250
Mono version (if Sonarr is not running on Windows): Windows
OS: Windows 10E x64
Debug logs: NA
I’m trying to import the Sonarr calendar into gmail calendar via the ical link, however, nothing shows up on the google calendar. No errors in gmail or the browser.
My link looks like this: https://mydomain.com/sonarr/feed/calendar/Sonarr.ics?asAllDay=true&apikey=REDACTED
I can browse to that link in an incognito session and it downloads the ical raw file.
This DOES work with Outlook OWA and Outlook Desktop application just great.
I’ve disabled authentication completely for testing.
Radarr DOES work:
https://calendar.google.com/calendar/embed?src=de5uvpembor144r3v3n66ejm1gamimn9%40import.calendar.google.com&ctz=America%2FDenver
Any ideas?
Outlook OWA:
Outlook desktop:
Just tested it in gmail and it’s working fine for me. Not sure why it wouldn’t for you.
@markus101 good to hear from you Sir.
Humm…weird, I mean, there’s not much to screw up here right? Any ideas what to check?
@markus101 Figured it outl
So I took out the " asAllDay=true " portion of the link and it works now.
Link looks like this: https://mydomain.com/sonarr/feed/calendar/Sonarr.ics?apikey=REDACTED
Cheers mate.
Interesting that it causes it to be hidden when that’s used.
