I changed from WIFI to LAN and now all TV-series gone?
Hello,
I´ve been running the latest NZBDrone for Mac for two weeks now and i decided to restart my Mac Mini and also connect TP cable instead of just WIFI. When I started NZBDrone from the Terminal it says:
[Warn] StaticResourceMapper: File /Users/martin/Downloads/NzbDrone/UI/Content/Images/background/logo.png), url(http://localhost:8989/Content/Images/background/black.png not found
[Warn] GlobalExceptionHandlers: SignalR Heartbeat error.
I looked at the webpage on localhost:8989 and it says You must be new around here, You should add some series. :frowning: All my TV-series are gone. Whats happening?? Is it because LAN has another IP? Or is it bound to the WIFI network card somehow?
Help is much appreciated
/Martin
Did you change the user drone is running under? That or nzbdrone.db was deleted as that is the only other thing that explains the database being reset.
Hello and thank you, i haven’t change anything in the NZBDrone folder. All i did was change from WIFI to LAN and rebooted my Mac. Is the database called nzbdrone.db? Casue i can’t find it.
Yes it is, you can find the location of the currently used on on the System Info page in drone, the AppData directory.
I found nzbdrone.db under
Mac-mini:NzbDrone martin$ ls -lh /Users/martin/.config/NzbDrone/
total 2800
drwxr-xr-x 3 martin staff 102B 19 Aug 20:39 Backups
drwxr-xr-x 3 martin staff 102B 18 Aug 21:36 MediaCover
-rw-r–r-- 1 martin staff 529B 18 Aug 21:33 config.xml
drwxr-xr-x 3 martin staff 102B 5 Aug 22:49 logs
-rw-r–r-- 1 martin staff 163K 19 Aug 20:27 logs.db
-rw-r–r-- 1 martin staff 167K 19 Aug 19:02 nzbdrone.db
-rw-r–r-- 1 martin staff 32K 19 Aug 20:11 nzbdrone.db-shm
-rw-r–r-- 1 martin staff 1,0M 19 Aug 20:40 nzbdrone.db-wal
-rw-r–r-- 1 martin staff 4B 18 Aug 21:33 nzbdrone.pid
And not under /Application
It was:
Mac-mini:NzbDrone martin$ ls -lh /Applications/NzbDrone/*
-rw-r–r--@ 1 martin staff 297K 24 Jul 01:46 /Applications/NzbDrone/DDay.iCal.dll
-rw-r–r--@ 1 martin staff 42K 24 Jul 01:46 /Applications/NzbDrone/Exceptron.Client.dll
-rw-r–r--@ 1 martin staff 11K 24 Jul 01:47 /Applications/NzbDrone/Exceptron.Client.dll.mdb
-rw-r–r--@ 1 martin staff 199K 24 Jul 01:46 /Applications/NzbDrone/FluentMigrator.Runner.dll
-rw-r–r--@ 1 martin staff 80K 24 Jul 01:47 /Applications/NzbDrone/FluentMigrator.Runner.dll.mdb
-rw-r–r--@ 1 martin staff 98K 24 Jul 01:46 /Applications/NzbDrone/FluentMigrator.dll
-rw-r–r--@ 1 martin staff 42K 24 Jul 01:47 /Applications/NzbDrone/FluentMigrator.dll.mdb
-rw-r–r--@ 1 martin staff 101K 24 Jul 01:46 /Applications/NzbDrone/FluentValidation.dll
-rw-r–r--@ 1 martin staff 32K 24 Jul 01:47 /Applications/NzbDrone/FluentValidation.dll.mdb
-rw-r–r--@ 1 martin staff 60K 24 Jul 01:46 /Applications/NzbDrone/Growl.Connector.dll
-rw-r–r--@ 1 martin staff 28K 24 Jul 01:46 /Applications/NzbDrone/Growl.CoreLibrary.dll
-rw-r–r--@ 1 martin staff 196K 24 Jul 01:46 /Applications/NzbDrone/ICSharpCode.SharpZipLib.dll
-rw-r–r--@ 1 martin staff 24K 24 Jul 01:46 /Applications/NzbDrone/Loggly.dll
-rw-r–r--@ 1 martin staff 109K 24 Jul 01:46 /Applications/NzbDrone/Marr.Data.dll
-rw-r–r--@ 1 martin staff 45K 24 Jul 01:47 /Applications/NzbDrone/Marr.Data.dll.mdb
-rw-r–r--@ 1 martin staff 31K 24 Jul 01:46 /Applications/NzbDrone/MediaInfoDotNet.dll
-rw-r–r--@ 1 martin staff 372B 24 Jul 01:46 /Applications/NzbDrone/MediaInfoDotNet.dll.config
-rw-r–r--@ 1 martin staff 258K 24 Jul 01:46 /Applications/NzbDrone/Microsoft.AspNet.SignalR.Core.dll
-rw-r–r--@ 1 martin staff 96K 24 Jul 01:47 /Applications/NzbDrone/Microsoft.AspNet.SignalR.Core.dll.mdb
-rw-r–r--@ 1 martin staff 43K 24 Jul 01:46 /Applications/NzbDrone/Microsoft.AspNet.SignalR.Owin.dll
-rw-r–r--@ 1 martin staff 13K 24 Jul 01:47 /Applications/NzbDrone/Microsoft.AspNet.SignalR.Owin.dll.mdb
-rw-r–r--@ 1 martin staff 84K 24 Jul 01:46 /Applications/NzbDrone/Microsoft.Owin.Host.HttpListener.dll
-rw-r–r--@ 1 martin staff 62K 24 Jul 01:46 /Applications/NzbDrone/Microsoft.Owin.Hosting.dll
-rw-r–r--@ 1 martin staff 69K 24 Jul 01:46 /Applications/NzbDrone/Microsoft.Owin.dll
-rw-r–r--@ 1 martin staff 430K 24 Jul 01:46 /Applications/NzbDrone/NLog.dll
-rw-r–r--@ 1 martin staff 8,5K 24 Jul 01:46 /Applications/NzbDrone/Nancy.Authentication.Basic.dll
-rw-r–r--@ 1 martin staff 13K 24 Jul 01:46 /Applications/NzbDrone/Nancy.Owin.dll
-rw-r–r--@ 1 martin staff 830K 24 Jul 01:46 /Applications/NzbDrone/Nancy.dll
-rw-r–r--@ 1 martin staff 393K 24 Jul 01:46 /Applications/NzbDrone/Newtonsoft.Json.dll
-rw-r–r--@ 1 martin staff 170K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Api.dll
-rw-r–r--@ 1 martin staff 40K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Api.dll.mdb
-rw-r–r--@ 1 martin staff 145K 24 Jul 01:46 /Applications/NzbDrone/NzbDrone.Common.dll
-rw-r–r--@ 1 martin staff 54K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Common.dll.mdb
-rw-r–r--@ 1 martin staff 677K 24 Jul 01:46 /Applications/NzbDrone/NzbDrone.Core.dll
-rw-r–r--@ 1 martin staff 224K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Core.dll.mdb
-rw-r–r--@ 1 martin staff 30K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Host.dll
-rw-r–r--@ 1 martin staff 8,0K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Host.dll.mdb
-rw-r–r--@ 1 martin staff 9,0K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Mono.dll
-rw-r–r--@ 1 martin staff 1,2K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.Mono.dll.mdb
-rw-r–r--@ 1 martin staff 11K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.SignalR.dll
-rw-r–r--@ 1 martin staff 2,6K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.SignalR.dll.mdb
-rw-r–r--@ 1 martin staff 23K 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.exe
-rw-r–r--@ 1 martin staff 1,4K 24 Jul 01:46 /Applications/NzbDrone/NzbDrone.exe.config
-rw-r–r--@ 1 martin staff 565B 24 Jul 01:47 /Applications/NzbDrone/NzbDrone.exe.mdb
-rw-r–r--@ 1 martin staff 20K 24 Jul 01:46 /Applications/NzbDrone/Omu.ValueInjecter.dll
-rw-r–r--@ 1 martin staff 4,5K 24 Jul 01:46 /Applications/NzbDrone/Owin.dll
-rw-r–r--@ 1 martin staff 14K 24 Jul 01:46 /Applications/NzbDrone/Prowlin.dll
-rw-r–r--@ 1 martin staff 157K 24 Jul 01:46 /Applications/NzbDrone/RestSharp.dll
-rw-r–r--@ 1 martin staff 199K 24 Jul 01:46 /Applications/NzbDrone/System.Data.SQLite.dll
-rw-r–r--@ 1 martin staff 12M 24 Jul 01:46 /Applications/NzbDrone/libmediainfo.0.dylib
-rw-r–r--@ 1 martin staff 619K 24 Jul 01:46 /Applications/NzbDrone/libsqlite3.0.dylib
-rw-r–r--@ 1 martin staff 18B 24 Jul 01:46 /Applications/NzbDrone/libsqlite3.dylib
/Applications/NzbDrone/NzbDrone.Update:
total 2696
-rw-r–r--@ 1 martin staff 42K 24 Jul 01:46 Exceptron.Client.dll
-rw-r–r--@ 1 martin staff 11K 24 Jul 01:47 Exceptron.Client.dll.mdb
-rw-r–r--@ 1 martin staff 196K 24 Jul 01:46 ICSharpCode.SharpZipLib.dll
-rw-r–r--@ 1 martin staff 24K 24 Jul 01:46 Loggly.dll
-rw-r–r--@ 1 martin staff 430K 24 Jul 01:46 NLog.dll
-rw-r–r--@ 1 martin staff 393K 24 Jul 01:46 Newtonsoft.Json.dll
-rw-r–r--@ 1 martin staff 145K 24 Jul 01:46 NzbDrone.Common.dll
-rw-r–r--@ 1 martin staff 54K 24 Jul 01:47 NzbDrone.Common.dll.mdb
-rw-r–r--@ 1 martin staff 9,0K 24 Jul 01:47 NzbDrone.Mono.dll
-rw-r–r--@ 1 martin staff 1,2K 24 Jul 01:47 NzbDrone.Mono.dll.mdb
-rw-r–r--@ 1 martin staff 15K 24 Jul 01:46 NzbDrone.Update.exe
-rw-r–r--@ 1 martin staff 507B 24 Jul 01:46 NzbDrone.Update.exe.config
-rw-r–r--@ 1 martin staff 2,9K 24 Jul 01:47 NzbDrone.Update.exe.mdb
/Applications/NzbDrone/UI:
total 4432
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 AddSeries
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 Calendar
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 Cells
drwxr-xr-x@ 13 martin staff 442B 18 Aug 21:35 Content
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 Handlebars
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 History
drwxr-xr-x@ 5 martin staff 170B 5 Aug 22:48 JsLibraries
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 Series
drwxr-xr-x@ 3 martin staff 102B 5 Aug 22:48 Settings
drwxr-xr-x@ 5 martin staff 170B 13 Aug 21:09 System
-rw-r–r--@ 1 martin staff 1,9M 24 Jul 01:47 app.js
-rw-r–r--@ 1 martin staff 3,5K 24 Jul 01:47 index.html
-rw-r–r--@ 1 martin staff 273B 24 Jul 01:47 main.js
-rw-r–r--@ 1 martin staff 1,4K 24 Jul 01:47 polyfills.js
-rw-r–r--@ 1 martin staff 291K 24 Jul 01:47 templates.js
How ever, its like it has been overwritten somehow
I also have this in the logs
Owin
/Applications/NzbDrone/Microsoft.AspNet.SignalR.Core.dll Error : 0 : SignalR exception thrown by Task: System.AggregateException: One or more errors occured —> System.IO.IOException: Write failure —> System.Net.Sockets.SocketException: The socket has been shut down
at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in :0
at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in :0
at System.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in :0
at System.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in :0
at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in :0
–> (Inner exception 0) System.IO.IOException: Write failure —> System.Net.Sockets.SocketException: The socket has been shut down
And when i start up i get this
File /Applications/NzbDrone/UI/Content/Images/background/logo.png), url(http://localhost:8989/Content/Images/background/black.png not found
But the black.png file is there.
I saw that i had a backup from the 16th so i restored that db and xml file but it was still empty, no TV-Series and no indexers and so on.
drone is running under the user martin? That looks like the correct location for it.
Is there some sort of redirect for your home folder that only takes effect when plugged into the LAN?
The signalR error can be ignored, the image file is something we’ll need to look at, but its not hurting anything right now.
