Sonarr Version
2.0.0.4689
Mono Version
4.6.2
Synology NAS
Enabled SSL
Converted key to PVK
setup HTTPCFG as requested
Everything works fine on HTTP, no issues, runs for hours.
The moment any connection is made to HTTPS, fatal error
Log:
17-4-28 12:35:35.8|Info|Bootstrap|Starting Sonarr - /volume1/@appstore/nzbdrone/share/NzbDrone/NzbDrone.exe - Version 2.0.0.4689
17-4-28 12:35:38.8|Info|MigrationLogger|*** Migrating data source=/var/services/homes/nzbdrone/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-4-28 12:35:39.6|Info|MigrationLogger|*** Migrating data source=/var/services/homes/nzbdrone/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-4-28 12:35:39.8|Info|Router|Application mode: Interactive
17-4-28 12:35:39.8|Info|OwinHostController|Listening on the following URLs:
17-4-28 12:35:39.8|Info|OwinHostController| http://*:8989/
17-4-28 12:35:39.8|Info|OwinHostController| https://*:8083/
17-4-28 12:35:40.3|Info|NancyBootstrapper|Starting Web Server
17-4-28 12:37:25.1|Fatal|GlobalExceptionHandlers|EPIC FAIL.
[v2.0.0.4689] System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: The client stopped the handshake.
at Mono.Security.Protocol.Tls.SslServerStream.EndNegotiateHandshake (System.IAsyncResult asyncResult) [0x00100] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/Mono.Security/Mono.Security.Protocol.Tls/SslServerStream.cs:272
at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallback (System.IAsyncResult asyncResult) [0x0000c] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/Mono.Security/Mono.Security.Protocol.Tls/SslStreamBase.cs:101
at Mono.Security.Protocol.Tls.SslStreamBase.EndRead (System.IAsyncResult asyncResult) [0x00058] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/Mono.Security/Mono.Security.Protocol.Tls/SslStreamBase.cs:886
at Mono.Net.Security.Private.LegacySslStream.EndAuthenticateAsServer (System.IAsyncResult asyncResult) [0x00011] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/Mono.Net.Security/LegacySslStream.cs:485
at Mono.Net.Security.Private.LegacySslStream.AuthenticateAsServer (System.Security.Cryptography.X509Certificates.X509Certificate serverCertificate, System.Boolean clientCertificateRequired, System.Security.Authentication.SslProtocols enabledSslProtocols, System.Boolean checkCertificateRevocation) [0x00000] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/Mono.Net.Security/LegacySslStream.cs:456
at System.Net.HttpConnection.Init () [0x0000b] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net/HttpConnection.cs:114
at System.Net.HttpConnection..ctor (System.Net.Sockets.Socket sock, System.Net.EndPointListener epl, System.Boolean secure, System.Security.Cryptography.X509Certificates.X509Certificate cert) [0x00096] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net/HttpConnection.cs:100
at System.Net.EndPointListener.ProcessAccept (System.Net.Sockets.SocketAsyncEventArgs args) [0x00052] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net/EndPointListener.cs:124
at System.Net.EndPointListener.OnAccept (System.Object sender, System.Net.Sockets.SocketAsyncEventArgs e) [0x00000] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net/EndPointListener.cs:133
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted (System.Net.Sockets.SocketAsyncEventArgs e) [0x00014] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net.Sockets/SocketAsyncEventArgs.cs:212
at System.Net.Sockets.SocketAsyncEventArgs.Complete () [0x00000] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net.Sockets/SocketAsyncEventArgs.cs:202
at System.Net.Sockets.Socket.<AcceptAsyncCallback>m__0 (System.IAsyncResult ares) [0x000a0] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net.Sockets/Socket.cs:974
at System.Net.Sockets.SocketAsyncResult+<Complete>c__AnonStorey0.<>m__0 (System.Object _) [0x00000] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/System/System.Net.Sockets/SocketAsyncResult.cs:150
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () [0x00019] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/referencesource/mscorlib/system/threading/threadpool.cs:1277
at System.Threading.ThreadPoolWorkQueue.Dispatch () [0x00096] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/referencesource/mscorlib/system/threading/threadpool.cs:854
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () [0x00000] in /spksrc/native/mono/work-native/mono-4.6.2/mcs/class/referencesource/mscorlib/system/threading/threadpool.cs:1209
