HTTPS certificate store errors
Sonarr version (exact version): 2.0.0.4689
Mono version (if Sonarr is not running on Windows): 4.6.2
OS: QNAP version 4.3.3 (latest)
((Debug logs)): https://******.org/api/torrents Curl Error 77 for Url https://******.org/api/torrents, issues with your operating system SSL Root Certificate Bundle (ca-bundle).
Description of issue: New SSL error with a private tracker indexer and RSS feed (directly supported in Sonarr). Since updated security setup enforced on private site, Sonarr now errors out with the above error. The RSS feed works on a Windows box, and also works through rtorrent RSS manager, so SSL certificate bundle must be failing either within Sonarr or within Mono. Trying update to latest version of Mono, but regardless may need update in Sonarr.
Nevermind - confirmed that update to Mono 4.8.0 has fixed problem with new security settings for private tracker…
Will leave this up in case any other people get this issue…
