HTTP(s) Proxy Settings
I live in the UK and it is getting increasingly difficult to get to torrent sites due to ISP blocking. I have access to a TOR/PRIVOXY box that i use as a way around this for Couchpotato and used to use for SickRage. It would be great to allow for setup of HTTP(s) proxy from inside Sonarr (i know you could use the system proxy settings but this seems abit overkill and also more difficult for advanced setups (docker container instances for example). Please can you add this to Sonarr.
Cheers
There are multiple topics on this subject.
We don’t plan on integrating proxies directly into Sonarr at this time.
