How to use as indexer RARBG
Hi all,
i’m pretty new to the Sonarr world and i use only my Windows PC to download the series.
What i’m having difficulty is adding RARBG as indexer.
It is correctly listed in the indexers list but i don’t know what api url i have to use, the one that is currently used doesn’t work for me (torrentapi).
Do you have any suggestions?
It may be blocked by your ISP so you would need to find a proxy if thats the case.
You may also want to test it as http:// rather than the default https:// just in case: https breaks this one for me, though I am using OS X and I’m not sure if the SSL issue with some domains affects windows users or not.
I have found out what the problem was :wink:
I had to specify the php page for RARBG.
