I’m a recent convert from SickRage. Currently I have Sonarr (formally SR) and Couch Potato sharing the use of Deluge. Deluge is configured to label torrents based on the tracker, which in turn dictates how long they seed for and (in a couple cases) what folder they’re moved to after finishing.
Both SR and CP have unRAR functionality, which is very useful as it seems that most private torrent sites (like TorrentLeech) RAR all their releases. These same private trackers also tend to get the show before the public trackers.
What I’m wondering is, how should I configure Sonarr/Deluge to unRAR files without breaking the rest of the setup? I know a little bit of scripting (CMD) but very little powershell and no Python whatsoever. I’d be willing to run a separate daemon of Deluge just for Sonarr, but I’d like to avoid that if possible.
It seems you are right. it asks for a extract directory. This could be the drone factory dir, but I’d rather keep that disabled.
I’ll take a look at extract scripts when I got some spare time.
