Sonarr version (exact version): 3.0.3.688
Mono version (if Sonarr is not running on Windows):5.20.1.34
OS: Doccker
Description of issue: So my stack is not simple…
Sonarr
Jackett
Synology
FileBot
Emby / Kodi / Plex
At the moment, sonar monitors, and sends the download to Synology, it downloads the file as expected. Every 2 hours, a scheduled process picks up the file and places into the correct location, with correct name etc.
Sonnar sees it as still downloading on synology until I manually press clean to remove it from the completed list.
Sonarr never sees it on disk and gets late notifications of the download being complete, as I manually clean the Synology complete list.
What this means, is that episodes are downloading over and over again.
I have set “Ignore Deleted Episodes”, however this doesn’t seem to do anything… Manually telling it to stop monitoring is just pure crazy, makes the point of having an automated setup pointless.
Even if I was to allow sonarr to see where the files are moved to, becuase filebot is taking care of the renaming, I assume it will just continue.
How can I stop this craziness?
