Sonarr version (exact version): 3.0.6.1265
OS: Docker 3.0.6.1265-ls111 by linuxserver.io
Debug logs: https://gist.github.com/enchained/0b6774b84b71afaaf159c1ae42855cd3
I have a lot of anime in Sonarr. Recently I added eztv indexer (from jackett) for a couple of specific (non-anime) series. And now, my preferred anime releases from nyaa almost always are getting upgraded to eztv releases. I supposed it’s because eztv names its anime releases with WEB-DL, while most groups from nyaa (which I prefer) - don’t.
All of my anime titles marked as Anime Series Type, my eztv indexer settings have TV (5000) in Categories, and Anime Categories are empty. I expected that it’ll ignore anime if left empty, and it does so in Interactive Search - no results there from eztv on anime. But in the background, it still upgrades anime from that indexer. But if later I Interactive Search and grab a release from nyaa, it doesn’t upgrade later it with eztv anymore. My guess is - the issue has something to do with RSS - the release is simply gone from the feed, so it doesn’t upgrade later, and the Interactive Search doesn’t use RSS, and the RSS possibly doesn’t have Categories restrictions, unlike API? I could try disabling RSS for eztv in the indexer settings, but what’s troubling me, will there be any delays to providing content from the indexer without it? Does Automatic Search from Sonarr run on the same (15 min) schedule as RSS Sync? Or will I miss out on speed without RSS enabled, and will need to run Automatic Search manually?
I already tried setting eztv indexer priority to the lowest (50), and adding eztv to preferred words with -25 in the default profile, but that expectedly didn’t work. In theory, tagging all of the anime and completely disabling eztv keyword for that tag via profile could work, but the anime titles are the most dynamic ones for me - new titles starting being added daily every third month or so. I hoped I could use Anime Series Type similar to a tag in a profile, but it doesn’t look like it (should I try to make a feature request, or is it maybe planned?).
Is there any other way to achieve what I need, besides running a second Sonarr instance with eztv + a few series? I wouldn’t want to split the database if there’s anything else I can try.
Would appreciate any help, thanks!
Logs and examples:
The title in example is Uramichi, and from its episode history:
- 18:16 Episode grabbed from Nyaa and sent to transmission - SubsPlease
- 18:17 Episode downloaded successfully and picked up from download client - SubsPlease
- 20:05 Episode grabbed from eztv jackett and sent to transmission - SUGOI
- 20:06 Episode file deleted - SubsPlease
- 20:06 Episode downloaded successfully and picked up from download client - SUGOI
- 20:20 Episode grabbed from eztv jackett and sent to transmission - SUGOI (I wonder why? Transmission ignored it - I have auto-delete disabled, and it’s the last event in the episode history).
Full debug logs for the same period: https://gist.github.com/enchained/0b6774b84b71afaaf159c1ae42855cd3
