the speed subs group is: Pafu
the proper subs group name is: dragonteam
I made a restriction for the series where it must cointain Pafu and dragonteam. It downloads Pafu since it is first but when dragonteam comes out, it doesn’t download it. How can I change the settings so it can replace Pafu with dragonteam?
they are both HDTV-720p
You can’t do this automatically, since they are the same quality Sonarr won’t grab a release of the same quality again.
i dont think this not possible, but you can prevent sonarr from download the pafu release. if you use release restrictions in the indexer settings
But then that would prevent any pafu releases from being downloaded. Wouldn’t the restrictions be more sensible under the profiles rather than indexers? Seems like this comes up pretty often. Restricting releases at the indexer level seems a bit…restrictive lol
you can do it on show level too. that is where the tag system gets used
Huh. A search for “sonarr tags” brings this up…
…which seems to be something entirely different. The documentation for sonarr is woefully inadequate. I wonder how many features people are completely unaware of because they aren’t documented properly anywhere except by stumbling across them in the forums.
