How to bulk rename
So just setup my Sonarr.
I need to run the renamer.
Is there a way i can do it as a batch. Run everything in one click.
Also not sure what I have done wrong but it is not downloading anything.
Any ideas?
Thanks in advance
you can use the series editor for that
But is that just one show at a time?
If I have several to rename in the same series, I use 1-4a Rename. It looks old and dated but it’s feature-rich and powerful. The website has examples in how to use it.
You didn’t offer much information to work from. My first steps would be to go into settings - check (test) the connection between Sonarr and your download client (like Sab). If that’s working then I would test the connection of the download client to the usenet server. If you still are having problems, then the logs would be the next place to check.
