How do I temporarily disable searches for mssing episodes
Bad news: A corrupted disk on a spanned volume lost all my media. Good News: I have a good backup copy of it. Bad news it’ll take days to copy over.
So there will be loads of missing episodes, I can’t go series by series, I need a single toggle to turn off searcing of missing episodes, then turn it back on again afterwards.
Is there an easy way of doing this, or shall I just shutdown sonarr while the copyig is going on?
Thanks for your help
Version2.0.0.4230
Mono Version3.2.8 (Debian 3.2.8+dfsg-4ubuntu1.1)
Sonarr doesn’t search for missing episodes, it only watches RSS feeds (as explained in the ((FAQ))), if you want to disable that functionality, disable RSS Syncing in settings (set interval to 0) or you could shutdown Sonarr.
You’ll want to upgrade mono, 4.0+ (4.6 is now available).
Thanks Markus, what’s the advantage of upgrading mono?
We don’t support mono less than 3.10 as there are numerous issues.
