How do I migrate from Done Factory to Completed Download Handling using qBittorent?
Sonarr version (exact version): develop most recent version
Mono version (if Sonarr is not running on Windows): windows 10
OS:
((Debug logs)):
I was using drone factory but I read that it was bad so I want to migrate to completed download handling.
I enabled Completed download handling and added Yes for Remove as well.
I deleted the drone factory folder path so it’s blank and the interval is 0. It saved successfully.
Is that all I have to do?
If qBittorrent and Sonarr are on the same machine, that’s should be it.
