Help with Sonarr Mac Monterey on M1
Sonarr version (exact version): 3
Mono version (if Sonarr is not running on Windows): 6.12
OS: Mac Os 12.4 Mac M1
I have Installed sonarr and Mono. I run Sonarr but when I go to the localhost, it fails.
Please make you installed per the instructions here https://wiki.servarr.com/sonarr/installation#macos-osx
Please try and grab log files per https://wiki.servarr.com/sonarr/troubleshooting#logging-and-log-files
Yes, All was installed accordingly.
Does it have any dependencies? like XCode tools? Visual studio?
Still doesn’t open the app. How can I extract logs without the app being opened?
Thanks!
I am not aware of any dependencies, but I am not familiar with Mac install so there may be. However, nothing is mentioned in the installation notes so I am leaning towards No.
The link I provided included details on how to get the logs if you can’t get into the UI, including how to change the logging level if required. You should just be able to navigate to the path and find the log files there. https://wiki.servarr.com/sonarr/troubleshooting#standard-logs-location
For someone that is not a developer… I can’t go any further. That documentation is too heavy for me.
I Think I’ll have to give up at this point. Thanks fanboy.
https://wiki.servarr.com/sonarr/appdata-directory#macos-osx
Go to /Users/$USER/.config/Sonarr or ~/.config/Sonarr
Grab the log file. Upload it per https://wiki.servarr.com/sonarr/troubleshooting#sharing-logs
Paste the link back here
