Help with sonarr and seedbox
Sonarr version (exact version): 2.0.0.4472
Mono version (if Sonarr is not running on Windows): 4.2.3
OS: Unraid docker
Debug logs: http://pastebin.com/raw/Kp4QF8RQ
Description of issue: I have a seedbox where I have deluge running and I have sonarr installed locally in a docker in unRAID. What I want to do is have sonarr send everything to deluge on the remote seedbox and have all the downloading happen there and then once the file has finished downloading, I want to have the files moved to a completed folder and then have that completed folder synced back locally to unRAID where Sonarr is running. I set up a drone factory folder for testing purposes and then read that is not the best way to do what I want to do. So what I am trying to do is have sonarr detect all of those shows from the locally synced completed folder and then rename them and sort them into their respective folders in my media folder for Plex to be able to see.
