Help with shows not going into folders
Hey everyone,
Having a little issue with sonarr. I had this all set up previously but had to reinstall. I have a /tv/ folder. Each show would be like such /tv/chicagopd/seasons episodes whatever… It is not putting the shows into the correct folders. Here are some screenshots. Can someone help. Be williing to paypal you a few dollars if someone can help me fix this.
As you can see so say for alaska state troppers it just puts the episodes not in the correct series folder. Then it keeps downloaiding the same episode over and over cause it doesnt seem to find it. HELP PLEASE this is driving me insane. I know its a stupid setting somewhere that im overlooking.
Thanks
First off, don’t mix unsorted and sorted files.
Your download client should extract files to a separate location so Sonarr can pick them up. Also make sure you’re using a category with your download client (and its set in Sonarr).
What do you mean unsorted and sorted files? It sorted forever until i reinstalled. This worked since released but then my server crashed and i had to reinstall everything now it dont work. Usually all that stuff would be in the appropriate TV Show folers. Markus would you be willing to Teamview in and fix this ill pay you fifty bucks thru paypal?
The fact that you have unsorted files (in folders, like Arrow S03E15) sitting right next to the sorted folder for Arrow. Thats not your issue here, but it could be an issue at some point.
Jump on IRC and I can take a look if you want:
http://webchat.freenode.net/?channels=#sonarr
