Help with scripts
Sonarr version (exact version): 2.0.0.4545
Mono version (if Sonarr is not running on Windows): 4.6.1r1
OS: ASUSTOR AS6204T
Description of issue: Scripts and auto start…
I just got this response from ASUSTOR tech support:
For the question you mentioned, you can follow the the steps below to run the demon on system startup
  1. login NAS as “root” via ssh client (e.g. Utility like “Putty” on Windows or “terminal” on Mac)
  2. Put your script under /usr/local/etc/init.d/
  3. Rename script name to SXXscript_name (S00 ~ S99: script execute order, S00 is in order of first, S99 is in order of last)
  4. Modify execute permission for this script
    e.g. # chmod +x /usr/local/etc/init.d/S99last
Apologies for being a noob at this, but I have little experience with Linux…
Asustor says “put your script”… What is a script file? What should the filename
of this script file be? Also, how do I copy said script file to: “/usr/local/etc/init.d/”?
And as for modifying the execute permission?
