Sonarr version (exact version): Version
2.0.0.5085 Mono version (if Sonarr is not running on Windows): OS: Windows 10 ((Debug logs)): https://pastebin.com/z9YCCLpZ Description of issue: Im having a bit of trouble understanding how I change the renaming settings.
I like my files to to be named E1 - Winter is Coming, which means in the settings I should have it set as E{episode} - {Episode Title}, right?
However, when I set that I get “Invalid Format” and it will not save.
The file structure I like is
Game of Thrones
** Season 1
*** E1 - Winter is Coming
Am I missing something?
This is causing problems with my watch list, as I have episodes already downloaded and its trying to redownload them because its not seeing them.
And yes, I know I have other problems with my set up, I’m tyring to correct that, Im just having a little trouble understanding how this all works
Oh right, So its not something I’ve done wrong, Its simple that its not supported at the moment.
Thanks for that.
Just another quick questions @markus101 ,If I have my indexer set as a Usenet, do I have to use a Usenet Download client?
From what I can see I have uTorrent set up right, but Sonarr is not sending torrents to it to download.
I did setup Nzbget last night, but I think I need to pay for a server to actually download? Sonarr sent the files to download, but after 45mins it hadn’t downloaded anything. So, im rather confused.
