Please see the quick start guide, the FAQ, and the troubleshooting guide to understand how sonarr works, that two files are expected, and to troubleshoot your issue.
https://wiki.servarr.com/sonarr
Itās also strongly suggested to not use utorrentā¦ the world has long moved passed that crapware many years agoā¦ Qbit is used these days
Remote path map is certainly not needed in your situation
Also ensure you read and grok the installation instructionsā¦it sounds like you may not have read them at all.
Sonarr is supported natively on Windows. Sonarr can be installed on Windows as Windows Service or system tray application.
can be installed as system tray application or Windows Service. A system tray application is started after the user logs in and is visible as an icon on the taskbar system tray.
A Windows Service runs even when the user is not logged in, but special care must be taken since Windows Services cannot access network drives (\server\share or X:\ mapped drives) without special configuration steps.
Additionally the Windows Service runs under the āLocal Serviceā account, by default this account does not have permissions to access your userās home directory unless permissions have been assigned manually. This is particularly relevant when using download clients that are configured to download to your home directory.
Itās therefore advisable to install Sonarr as a system tray application if the user can remain logged in. The option to do so is provided during the installer.
