Hi, i have upgraded to to v3 and i can not login to the sonarr GUI.
Any help would be great.
Either Sonarr is already running or NZBDrone is still installed and already running
or your didn’t run as admin to start? but likely the second option - you never uninstalled v2
Hi, how do i check if NZBdrone is still running? ive looked in programmes and cant seem to find it. I see Sonarr V3 is installed
Thanks for your help, I done the following and now seems to be working great.
netsh http delete urlacl http://ip address:8989/
