So I have done the setup. All the checks work and there are no known errors.
I searched for a series on Sonarr and it then seemed to be downloading in SABnzbd and from there I have no files.
I have checked the completed file directory, nothing. While it was downloading I could see activity in the incomplete directory.
So what happened? where did my downloads go?
Also is there a resource that can talk me through using sonarr (not setup). It all feels a little daunting to figure out.
If you have configured sonarr to remove completed downloads, it also clears the sabnzbd logs. Only way to check is in the history section of the activity log in sonarr.
The complete file should have been transfered to the folder you set your series to.
If there is a successful download for one of the grabs, press the black “i” icon. The “Imported To” will be the directory where Sonarr placed the file.
Well offhand, as far as I know Giganews has the longest retention (at 2567 I think) so I don’t think any usenet provider would have the articles for that NZB. It should be showing up as a failed download.
