Hi,
Recently switched to NzbDrone from SickBeard.
Having great success with it so far. Love how fast and clean it is.
I’m having trouble grabbing 1 show though. Match of the Day 2.
NzbDrone picks up ‘Match of the Day’ fine. But not ‘Match of the Day 2’.
I think it’s because in the search results, it’s named as ‘Match of the Day Two’.
Even if I do a manual search, nothing comes up.
Is there a way around this?
Thanks in advance! Keep up the great work.
Drone already supports Match of the Day Two as an alternate name.
What do you get back when you do a manual search?
Hi Markus, thanks for replying. I’ve added both ‘Match of the Day’ and ‘Match of the Day 2’ as 2 separate shows.
Match of the Day works fine with regards to grabbing, downloading, and automatic/manual searching etc.
But with Match of the Day 2, I get nothing at all.
Nothing in both the automatic/manual search.
Is the ‘2’ instead of ‘Two’ confusing it?
This is how they are named:
Match Of The Day Two 2014 04 13
Thanks!
No, as stated above its already an alternate name that drone supports (http://forums.nzbdrone.com/discussion/135/scene-naming/p1)
Indexers are incorrectly treating this series as the original Match of the Day, so when drone searches by the tvrage id it fails to find any results. Searching by the name isn’t used and even if it was (I tested it) it would fail as well.
At this point you will either need to rely on the automatic grabbing when they are posted, or reach out to your indexer(s) to take a look.
Oh right I think I understand.
I’ll see how it gets on with next weeks episode.
