Hey Guys -
Yesterday, I noticed some of my shows hadn’t been updated. I opened Sonarr and found out it couldn’t talk to SABnzbd. CouchPotato and Headphones connected with same settings & API key just fine. After trying to connect to it for 20 minutes and trying every option possible, I restarted the service and eventually restart the computer.
After a bit more troubleshooting, I tried checking for an update from tasks but it failed.- strange. Finally, I decided to back everything up, uninstall Sonarr (NZBDrone), delete Program Files folder plus ProgramData folder, and remove registry keys (via Revo.) I did this, verified it was gone, then reinstalled with the newest download. After isntallation, I connected to the new instance via browser, went to Settings, changed release to Develop (what I was using before), saved, then went to have it check for updates again. This, too, failed.
I know what you’re thinking - that I have a firewall or something which is blocking the executable / app / port from communicating. Maybe so - but how can CouchPotato & Headphones connect? I did just have a malware issue which I removed but thought maybe website scanning was still on. It wasn’t, but I still uninstalled malwarebytes & spybot plus scanned task manager and applications for any app which could cause that. Nothing found. I’ve also been using my hostname to connect to SABnzbd, but also tried IP. Checked hosts file anyways and it’s clean.
Finally, I restarted and still have similar status. The current state is that I can successfully add and test indexers - but - cannot add and test SABnzbd and seemingly not check for app updates. I changed the logging level to Info, tried to add SABnzbd not using SSL (usually do use it) and below is what the log stated:
NzbDrone.Core.Download.Clients.DownloadClientException: Unable to connect to SABnzbd, please check your settings ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:58054
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetResponse()
at RestSharp.Http.GetRawResponse(HttpWebRequest request)
at RestSharp.Http.GetResponse(HttpWebRequest request)
at NzbDrone.Core.Download.Clients.Sabnzbd.SabnzbdProxy.CheckForError(IRestResponse response) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Sabnzbd\SabnzbdProxy.cs:line 149
at NzbDrone.Core.Download.Clients.Sabnzbd.SabnzbdProxy.ProcessRequest(IRestRequest restRequest, String action, SabnzbdSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Sabnzbd\SabnzbdProxy.cs:line 69
at NzbDrone.Core.Download.Clients.Sabnzbd.SabnzbdProxy.GetConfig(SabnzbdSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Sabnzbd\SabnzbdProxy.cs:line 92
at NzbDrone.Core.Download.Clients.Sabnzbd.Sabnzbd.TestAuthentication() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Sabnzbd\Sabnzbd.cs:line 377
at NzbDrone.Core.Download.Clients.Sabnzbd.Sabnzbd.Test(List`1 failures) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Sabnzbd\Sabnzbd.cs:line 341
at NzbDrone.Core.Download.DownloadClientBase`1.Test() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\DownloadClientBase.cs:line 83
15-1-14 16:48:14.4|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect to SABnzbd
-- Test was aborted due to an error: Unable to connect to SABnzbd, please check your settings
Note:In the listed addresses above is the code “6c3239faf2b92630.” I don’t know what it’s supposed to be, but it’s not any of my API keys. Didn’t know if that made a difference,
Any thoughts or ideas? Thanks!
UPDATE
I just tried an app update check task and copied the logging while I had it set to Info. Below is what it reported:
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 86
at NzbDrone.Common.Http.HttpClient.Get[T](HttpRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 161
at NzbDrone.Core.Update.UpdatePackageProvider.GetLatestUpdate(String branch, Version currentVersion) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Update\UpdatePackageProvider.cs:line 33
at NzbDrone.Core.Update.CheckUpdateService.AvailableUpdate() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Update\UpdateCheckService.cs:line 38
at NzbDrone.Core.Update.InstallUpdateService.Execute(ApplicationUpdateCommand message) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Update\InstallUpdateService.cs:line 159
at NzbDrone.Core.Messaging.Commands.CommandExecutor.ExecuteCommand[TCommand](Command command) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Commands\CommandExecutor.cs:line 137
at NzbDrone.Core.Messaging.Commands.CommandExecutor.<>c__DisplayClass9`1.<PublishCommandAsync>b__5() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Commands\CommandExecutor.cs:line 86
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
As for the ports its mentioning,58054; I don’t know if that’s where it’s supposed to look, but I have the console set to use the defaults of 8080 for non-SSL and 9090 for SSL. Both are currently accessable as I have my own purchased SSL cert installed.
Thanks
