I’m getting “Failed to import episode” with error:
Couldn't import episode /mnt/path/filename.mkv: Access to the path is denied.
Exception:
System.UnauthorizedAccessException: Access to the path is denied.
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x00000] in <filename unknown>:0
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, Boolean overwrite) [0x00000] in <filename unknown>:0
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) [0x00000] in <filename unknown>:0
It has previously proceed files for the series and all these files appear to be higher quality versions of episodes I already have. I’m running under freebsd, the owner and group are correct and I have even opened up, execute, read and write for everyone to paths and files with chmod 777.
I cannot understand why or were its getting stuck. Any idea’s?
Yep, that’s correct, owner and group are the sonarr service user and 777 doesn’t resolve it. Additionally the permissions given to files when using sonarr is 744, which should be ok.
If this helps, here is the Mono version
mono --version
Mono JIT compiler version 4.0.3 (Stable 4.0.3.20/d6946b4 Tue Aug 18 04:04:15 UTC 2015)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notification: kqueue
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
Good news, I found my problem. I had enabled the ‘Recycling Bin’ and it was permissions on this folder.
Interestingly, it was working at some point because there are files in there, however after changing the permissions it started working.
We should have a feature request to improve this logging/debugging. There are no messages that report what Sonarr is going prior to receiving the “Access to the path is denied” and no pointer to what folders are affected. I checked the log files and even enabled debugging on mono… Am I missing something?
