I use nzbget to grab files, and dump them into /media/video/temp
Drone is supposed to look there and post process and move the files from there. It seems like it is now copying, instead of moving. I’m going to look thru the logs as soon as I can, but wanted to see if anything has changed.
It may be a simple permissions issue.
Another issue, may or may not be related.
Drone found Lost girl for me:
14-2-17 14:30:02.3|Info|NzbgetClient|Adding report [Lost.Girl.S04E13.720p.HDTV.x264-2HD.nzb] to the queue.
14-2-17 14:30:02.3|Info|DownloadService|Report sent to download client. Lost.Girl.S04E13.720p.HDTV.x264-2HD
But it won’t post-process it. Here is what the file looks like in my Drone Factory folder useing the tree command:
|-- lost.girl.s04e13.720p.hdtv.x264-2hd.mkv
|-- lost.girl.s04e13.720p.hdtv.x264-2hd.nfo
|-- lost.girl.s04e13.720p.hdtv.x264-2hd.srr
`-- sample-lost.girl.s04e13.720p.hdtv.x264-2hd.mkv
I would think that the post processor would pick that up ok.
Should process fine, no change has been made to how its done (it still moves it). Enable Trace logging and check that.
Yea, just did, and I rebooted my VPS too, just in case.
EDIT: After reboot, it found the file. No idea . . .
So I cleared my drone factory folder, and I’ll watch it, with trace logging on.
