Hard links not working but not logging any error
Sonarr version (exact version): 2.0.0.4689
Mono version (if Sonarr is not running on Windows): n/a
OS: macOS Sierra
((Debug logs)): https://pastebin.com/rx1ngM5R
Sonarr says it’s linking the file (see logs). Both download and final directory are no the same drive. When I inspect the file after it is NOT a hard link.
The hard drive is connected to a windows machine -> shared via windows shared folder settings -> connected to on Mac that is running Sonarr. When Sonarr was running on the windows machine using the same drive and folders the hard links were working.
I’m not sure creating a hardlink over the network is supported.
Where are you inspecting it? You may have different results inspecting it from the the Mac vs the Windows machine depending how that is exposed (if even supported by the Windows machine).
Inspected from both. I think you are right that hard link just won’t work for network connected drives. Going to move the drive to the Mac - need to figure out how to get it writing to an NTFS drive though.
