Hard Drive Manager?
I was wondering if there is a hard drive manager inside sonarr so I can specify new folders to move all newly added series to a new drive. My server setup isnt exactly ideal as all my drives are seperate and not in any kind of RAID or spanned disk. I just got a new hard drive and I want to now set any new series I add to go to the new drive. Under System i can see the Disk Space section but I want to add another drive to that section.
Is there a way on sonarr to do this like a drive manager?
Latest Sonarr Version 2.0.0.4427 and running on Windows 10 VM.
Cheers
No, you need to add it to the system then Sonarr will see it. Sonarr will only be able to access a single folder for each series though.
