Handling of double episodes
Some series have double episodes ex. ___________.s8e11-12
This does not seem to be properly handles in Sonarr as I have found when importing a few series.
I imagine it will also have trouble with downloading as well.
How can i duplicate absolute episode numbers properly for double/triple episode files?
I did not understand the explanation here.
This is for a completely different issue (renaming, not parsing).
I’m not seeing any issues parsing that format for multi-episode files, we have pretty extensive support for multi-episode files. If you can give me a complete file name for something that is failing to import I can perform some additional tests, but as-is this one one fine.
I no longer have the original file name as Sonarr has renamed them
This was from importing a complete series.
