Hi, using the developer version of Sonarr in Firefox 39 in Windows 8.1, only since the last few days has the gui failed to start. It gets as far as the spinning balls and Sonarr Ver. If I open Sonarr in IE, the GUI opens perfectly. Everything works. I rolled back to Firefox 38 and same issue. I have made calls to the api using the F12 developer key in Firefox and as far as I can see the response is ok. I do get some errors. Can somebody help? Thanks.These are the errors in a pastebin file:
http://pastebin.com/QcxTqJhc
Hi, I solved this. Apparently because I set dom.storage.enabled in firefox config to false, it breaks the GUI. I also was seeing an error in SignalR - bad transport. I set this back to true and GUI is showing again in Firefox.
