Have a guest login page. It can be a simple UI tweak. Just remove all the settings buttons or modify series etc. Even a password can be added if necessary. We can then let our friends have a look at our TV Shows and calendar but also be assured that they won’t mistakenly change any settings.
A possible addendum, although it would take a lot more code, is let guests ‘suggest’ a series using the Add Series protocols so that they’d go into a que to be modified & approved.
+1
Guest Login : I suspect this would be a highly valuable / often used feature for those of us sharing with friend & family.
this will do along with this feature request…
File Download link for Series & Episodes - using the Sonarr UI
