Grabbing the highest quality copy
I find that Sonarr will add the best quality based on title such as 1080p > 720p but when it’s mislabeled or not right is there a way for Sonarr to also grab by file size?
I found a few times a 1080p labeled copy will only for 600MB for a 60 minute video which is just not right and there were plenty of files in the more appropriate 2.0GB+ range that were 1080p
Currently Sonarr prefers smaller releases, which is likely the culprit, on the Quality settings page you can set a minimum size to prevent small files like that from being grabbed.
