Getting some errors in my log - Input string was not in a correct format
I have been seeing the following error in my log:
An error occurred while processing feed. https://in/api?t=tvsearch&cat=5030,5040,5070&extended=1&apikey=&offset=0&limit=100: Input string was not in a correct format.
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at NzbDrone.Common.Http.TooManyRequestsException…ctor(HttpRequest request, HttpResponse response) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\TooManyRequestsException.cs:line 12
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 97
at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchIndexerResponse(IndexerRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 276 at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchPage(IndexerRequest request, IParseIndexerResponse parser) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 262
at NzbDrone.Core.Indexers.HttpIndexerBase`1.FetchReleases(IndexerPageableRequestChain pageableRequestChain, Boolean isRecent) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 142
Looks like you hit your API limit, but your indexer is likely reporting a date instead of a time in seconds so Sonarr is failing, we’ll need to handle that on our end.
