Getting "not a valid *nix path. paths must start with /" errors
Hey there, just dipping my toe into sonarr to see if it can replace my current sickrage setup. So far so good and loving the UI but I’m getting the following errors:
System.ArgumentException: value [/mnt/Videos/TV/Triptank]  is not a valid *nix path. paths must start with /
Parameter name: path
at NzbDrone.Common.EnsureThat.EnsureStringExtensions.IsValidPath (NzbDrone.Common.EnsureThat.Param`1<string>) <0x000ef>
at NzbDrone.Common.Disk.DiskProviderBase.GetPathRoot (string) <0x000df>
at NzbDrone.Core.DiskSpace.DiskSpaceService.<GetSeriesFreeSpace>b__2 (NzbDrone.Core.Tv.Series) <0x0002d>
at System.Linq.Enumerable/<CreateSelectIterator>c__Iterator10`2<NzbDrone.Core.Tv.Series, string>.MoveNext () <0x0017c>
at System.Linq.Enumerable/<CreateDistinctIterator>c__Iterator3`1<string>.MoveNext () <0x0029e>
at NzbDrone.Core.DiskSpace.DiskSpaceService/<GetDiskSpace>d__4.MoveNext () <0x00587>
at System.Collections.Generic.List`1<NzbDrone.Core.DiskSpace.DiskSpace>.AddEnumerable (System.Collections.Generic.IEnumerable`1<NzbDrone.Core.DiskSpace.DiskSpace>) <0x0008a>
at System.Collections.Generic.List`1<NzbDrone.Core.DiskSpace.DiskSpace>.AddRange (System.Collections.Generic.IEnumerable`1<NzbDrone.Core.DiskSpace.DiskSpace>) <0x00063>
at NzbDrone.Core.DiskSpace.DiskSpaceService.GetFreeSpace () <0x000a3>
at NzbDrone.Api.NzbDroneRestModule`1<NzbDrone.Api.DiskSpace.DiskSpaceResource>.ToListResource<NzbDrone.Core.DiskSpace.DiskSpace> (System.Func`1<System.Collections.Generic.IEnumerable`1<NzbDrone.Core.DiskSpace.DiskSpace>>) <0x0001e>
at NzbDrone.Api.DiskSpace.DiskSpaceModule.GetFreeSpace () <0x00067>
at NzbDrone.Api.REST.RestModule`1<NzbDrone.Api.DiskSpace.DiskSpaceResource>.<set_GetResourceAll>b__c (object) <0x0001a>
at (wrapper dynamic-method) object.CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object) <0x000a0>
at Nancy.Routing.Route/<>c__DisplayClass4.<Wrap>b__3 (object,System.Threading.CancellationToken) <0x00137>
I have my data on a nas with the cifs share mounted at '/mnt/Videos’
I’m getting these errors when I try to update a show in season pass, and I’m using the latest master build.
Any suggestions? Or if any more logs or info are required please ask.
Nevermind I just deleted that show and all the others are working.
