I mistyped the address for my server while setting up Sonarr and now I can’t login to Sonarr. What is the location of the settings file on a Mac so I might be able to edit it manually. Thanks.
You shouldn’t need to set the address in Sonarr at all unless you want to limit the addresses that can be used to connect to Sonarr (which will also affect remote connections). You can fix this issue by editing config.xml
and setting the BindAddress
to *
, it’s in the ((AppData Folder)).
