I seem to have enabled the full version of the forums on my mobile phone.
How do I re-enable the mobile theme again please?
Also, is there a “mark all as read” option please?
are you using the tapatalk app if not and just using the browser on your phone and assuming it is android (probably same on iOS as well but i have android so cannot say for sure)
for reference i am using Google Chrome app on my Samsung Galaxy S5
You have to clear the cache and close and re-open the browser so go to settings in chrome app then to privacy then down the bottom it says CLEAR BROWSING DATA do this and make sure cache is selected then let it do it’s thing then close and re-open the app and navigage to the forums you will then be prompted to use the TapaTalk app i skip this and it brings me back to the mobile site
I tested this on my S5 and it works would be nice for a button to switch between the two there is one to go to full site at the very bottom but nothing to switch back
Let us know here if it works for you
Hope this helps
Thanks Protocol77, that worked.
Would be nice to see an option on the forums to switch between the themes.
I usually close the page and kill the browser (force close on Android).
These forums suck, looking at switching
LOL
Mediabrowser have recently moved to an IPB forum, which is very good.
