18-4-23 01:21:38.2|Info|RssSyncService|Starting RSS Sync
18-4-23 01:21:55.2|Info|DownloadDecisionMaker|Processing 1124 releases
18-4-23 01:22:13.6|Info|DownloadService|Report sent to QBittorrent. The Arrangement S02E07 720p WEB x264-TBS EZTV
18-4-23 01:22:14.1|Info|RssSyncService|RSS Sync Completed. Reports found: 1124, Reports grabbed: 1, Reports pending: 32
18-4-23 01:37:38.9|Info|RssSyncService|Starting RSS Sync
18-4-23 01:38:12.2|Info|DownloadDecisionMaker|Processing 1128 releases
18-4-23 01:38:19.9|Info|Sabnzbd|Adding report [Last.Week.Tonight.with.John.Oliver.S05E09.720p.WEB-DL.AAC2.0.H.264-doosh] to the queue.
18-4-23 01:38:20.3|Info|DownloadService|Report sent to Newsbin. Last.Week.Tonight.with.John.Oliver.S05E09.720p.WEB-DL.AAC2.0.H.264-doosh
18-4-23 01:38:31.7|Info|RssSyncService|RSS Sync Completed. Reports found: 1128, Reports grabbed: 1, Reports pending: 6
18-4-23 01:53:39.6|Info|RssSyncService|Starting RSS Sync
18-4-23 01:53:56.3|Info|DownloadDecisionMaker|Processing 1105 releases
18-4-23 01:54:14.1|Warn|ProcessDownloadDecisions|Couldn't add report to download queue. The.Arrangement.S02E07.1080p.WEB.x264-TBS
[v10.0.0.29959] NzbDrone.Core.Download.InvalidNzbException: Invalid NZB: Unexpected root element. Expected 'nzb' found 'error' [The.Arrangement.S02E07.1080p.WEB.x264-TBS.nzb]
at NzbDrone.Core.Download.NzbValidationService.Validate(String filename, Byte[] fileContent) in I:\Code\HTPC\Sonarr\src\NzbDrone.Core\Download\NzbValidationService.cs:line 32
at NzbDrone.Core.Download.UsenetClientBase`1.Download(RemoteEpisode remoteEpisode) in I:\Code\HTPC\Sonarr\src\NzbDrone.Core\Download\UsenetClientBase.cs:line 76
at NzbDrone.Core.Download.DownloadService.DownloadReport(RemoteEpisode remoteEpisode) in I:\Code\HTPC\Sonarr\src\NzbDrone.Core\Download\DownloadService.cs:line 69
at NzbDrone.Core.Download.ProcessDownloadDecisions.ProcessDecisions(List`1 decisions) in I:\Code\HTPC\Sonarr\src\NzbDrone.Core\Download\ProcessDownloadDecisions.cs:line 76
18-4-23 01:54:14.8|Info|Sabnzbd|Adding report [The.Arrangement.S02E07.1080p.WEB.x264-TBS] to the queue.
18-4-23 01:54:15.2|Info|DownloadService|Report sent to Newsbin. The.Arrangement.S02E07.1080p.WEB.x264-TBS
18-4-23 01:54:15.5|Info|RssSyncService|RSS Sync Completed. Reports found: 1105, Reports grabbed: 1
18-4-23 02:01:40.2|Info|NzbSearchService|Searching 2 indexers for [The Arrangement (2017) : S02E07]
18-4-23 02:02:19.4|Info|DownloadDecisionMaker|Processing 54 releases
18-4-23 02:02:21.2|Info|Sabnzbd|Adding report [The.Arrangement.S02E07.1080p.WEB.x264-TBS] to the queue.
18-4-23 02:02:21.8|Info|DownloadService|Report sent to Newsbin. The.Arrangement.S02E07.1080p.WEB.x264-TBS
18-4-23 02:02:33.1|Info|EpisodeSearchService|Episode search completed. 1 reports downloaded.
18-4-23 02:05:23.2|Warn|DownloadedEpisodesImportService|Non-sample file detected: [E:\Downloaded\Newsbin\The.Arrangement.S02E07.1080p.WEB.x264-TBS.nzb\the.arrangement.s02e07.1080p.web.x264-tbs.mkv]
Sequence from activity page:
Grabbed & Sent to download client
Episode Download Failed
Downloaded Successfully and picked up from download client
The logs do not show any other downloading or sending to download client other then what is shown above.
Failed files and folder still exist in download folder.
Automatic import won’t pick them up (I think because they are now dups)
Manual import says “not an upgrade”, or “same file size”.
Running latest Sonarr on Win 10 x64
