[FIXED] Refresh of Specials folder does not work
Sonarr Ver. 2.0.0.5250
Mono JIT compiler version 5.10.1.20
Ubuntu 18.04.01 LTS
No debug logs
When I put episodes in the Specials folder for a series, I don’t want to bother with the acutal name (since sonarr should find and rename the file) so I will use S00E01.mkv, S00E02.mkv and so on. When I do a rescan in sonarr to find those episodes for renaming, it will not register those files. Only when I rename the episode EXACTLY to what is expected (S00E01 - Title.mkv), then will sonarr find it.
This works for all other numbered seasons like Season 01 and so forth. I can put a file like S01E01.mkv in the Season 01 folder and Sonarr will find and rename it as expected. It’s only the Specials folder where this doesn’t work (and I did try Season 00 as well, same issue)
There are no error logs when this happens, just an info log sequence like this:
Component Message Time
DiskScanService Scanning disk for Keeping Up Appearances 9:27pm
RefreshEpisodeService Finished episode refresh for series: [78079][Keeping Up Appearances]. 9:27pm
RefreshEpisodeService Starting episode info refresh for: [78079][Keeping Up Appearances] 9:27pm
RefreshSeriesService Updating Info for Keeping Up Appearances 9:27pm
ExistingExtraFileService Found 0 extra files 9:26pm
ExistingOtherExtraImporter Found 0 existing other extra files 9:26pm
ExistingSubtitleImporter Found 0 existing subtitle files 9:26pm
ExistingMetadataImporter Found 0 existing metadata files 9:26pm
DiskScanService Completed scanning disk for Keeping Up Appearances 9:26pm
You’re going to need to look at the debug logs to get more details, but Sonarr should have no issues linking it when it’s just named S00E01.mkv.
I was able to do a trace for this. Here’s a snippet of what I see:
code:
18-10-24 13:04:20.5|Info|DiskScanService|Scanning disk for One-Punch Man
18-10-24 13:04:20.5|Trace|EventAggregator|Publishing CommandUpdatedEvent
18-10-24 13:04:20.5|Trace|EventAggregator|CommandUpdatedEvent → CommandModule
18-10-24 13:04:20.5|Trace|EventAggregator|CommandUpdatedEvent ← CommandModule
18-10-24 13:04:20.5|Debug|DiskScanService|Scanning ‘/pub/Media/Video/Television/One-Punch Man’ for video files
18-10-24 13:04:20.5|Trace|DiskScanService|48 files were found in /pub/Media/Video/Television/One-Punch Man
18-10-24 13:04:20.5|Debug|DiskScanService|18 video files were found in /pub/Media/Video/Television/One-Punch Man
18-10-24 13:04:20.5|Trace|DiskScanService|Finished getting episode files for: [293088][One-Punch Man] [00:00:00.0113054]
18-10-24 13:04:20.5|Debug|DiskScanService|[293088][One-Punch Man] Cleaning up media files in DB
18-10-24 13:04:20.5|Debug|ImportDecisionMaker|Analyzing 6/18 files.
18-10-24 13:04:20.5|Debug|Parser|Parsing string ‘S00E02.mkv’
18-10-24 13:04:20.5|Trace|Parser|^(?:S?(?(?<!\d+)(?:\d{1,2}|\d{4})(?!\d+))(?:(?:[-_ ]?[ex])(?\d{2,3}(?!\d+))))
18-10-24 13:04:20.5|Debug|Parser|Episode Parsed. - S00E02
18-10-24 13:04:20.5|Debug|Parser|Language parsed: English
18-10-24 13:04:20.5|Debug|QualityParser|Trying to parse quality for S00E02.mkv
18-10-24 13:04:20.5|Debug|Parser|Quality parsed: HDTV-720p v1
18-10-24 13:04:20.5|Debug|Parser|Release Group parsed:
18-10-24 13:04:20.5|Trace|ConfigService|Using default config value for ‘enablemediainfo’ defaultValue:‘True’
18-10-24 13:04:20.5|Debug|VideoFileInfoReader|Getting media info from /pub/Media/Video/Television/One-Punch Man/Specials/S00E02.mkv
18-10-24 13:04:20.5|Trace|MediaInfo|Read file offset 0-11812864 (11812864 bytes)
18-10-24 13:04:20.5|Trace|MediaInfo|Read file offset 52058291-52074940 (16649 bytes)
18-10-24 13:04:20.5|Trace|MediaInfo|Read a total of 11829513 bytes (22.7%)
18-10-24 13:04:20.5|Debug|AggregateQuality|Using quality: HDTV-720p v1
18-10-24 13:04:20.5|Debug|ImportDecisionMaker|File rejected for the following reasons: [Permanent] Invalid season or episode
If I do the same thing with any numbered season (S01E01.mkv, for instance), it works.
I don’t see that Regex in the code, which version of Sonarr are you running now?
I do see a potential issue with specials, but that shouldn’t affect regular episodes named that way.
Sonarr Ver. 2.0.0.5251 develop
Is that something that is in the code, or can be changed in the config file? I know that regular seasons work, let me see if I can find a quick minute to try this with a season 1 file.
Here’s a successful one:
Code:
18-10-24 14:04:25.1|Debug|ImportDecisionMaker|Analyzing 7/18 files.
18-10-24 14:04:25.1|Debug|Parser|Parsing string ‘S01E12.mkv’
18-10-24 14:04:25.1|Trace|Parser|^(?:S?(?(?<!\d+)(?:\d{1,2}|\d{4})(?!\d+))(?:(?:[-_ ]?[ex])(?\d{2,3}(?!\d+))))
18-10-24 14:04:25.1|Debug|Parser|Episode Parsed. - S01E12
18-10-24 14:04:25.1|Debug|Parser|Language parsed: English
18-10-24 14:04:25.1|Debug|QualityParser|Trying to parse quality for S01E12.mkv
18-10-24 14:04:25.1|Debug|Parser|Quality parsed: HDTV-720p v1
18-10-24 14:04:25.1|Debug|Parser|Release Group parsed:
18-10-24 14:04:25.1|Trace|ConfigService|Using default config value for ‘enablemediainfo’ defaultValue:‘True’
18-10-24 14:04:25.1|Debug|VideoFileInfoReader|Getting media info from /pub/Media/Video/Television/One-Punch Man/Season 01/S01E12.mkv
18-10-24 14:04:25.1|Trace|MediaInfo|Read file offset 0-49152 (49152 bytes)
18-10-24 14:04:25.1|Trace|MediaInfo|Read file offset 605143005-605161801 (18796 bytes)
18-10-24 14:04:25.1|Trace|MediaInfo|Read a total of 67948 bytes (0.0%)
18-10-24 14:04:25.1|Debug|AggregateQuality|Using quality: HDTV-720p v1
18-10-24 14:04:25.1|Debug|EpisodeTitleSpecification|Episode aired more than 1 day ago
18-10-24 14:04:25.1|Trace|ConfigService|Using default config value for ‘skipfreespacecheckwhenimporting’ defaultValue:‘False’
18-10-24 14:04:25.1|Debug|FreeSpaceSpecification|Skipping free space check for existing episode
18-10-24 14:04:25.1|Debug|SameFileSpecification|No existing episode file, skipping
18-10-24 14:04:25.1|Debug|GrabbedReleaseQualitySpecification|No download client item provided, skipping.
18-10-24 14:04:25.1|Debug|NotSampleSpecification|Existing file, skipping sample check
18-10-24 14:04:25.1|Debug|NotUnpackingSpecification|/pub/Media/Video/Television/One-Punch Man/Season 01/S01E12.mkv is in series folder, skipping unpacking check
18-10-24 14:04:25.1|Debug|UnverifiedSceneNumberingSpecification|Skipping scene numbering check for existing episode
18-10-24 14:04:25.1|Debug|ImportDecisionMaker|File accepted
In this case, S01E12.mkv was accepted, where the S00E02.mkv above was not.
URL for metadata:
https://www.thetvdb.com/series/one-punch-man
Ahh, sorry misread your previous response.
I see what the issue is, I’ll get a fix out for it when I can.
Thanks! You may have read my original response before I added the successful trace.
Confirmed this is fixed in Sonarr Ver. 2.0.0.5270
