Hi Everyone
So when I have a series where the final 2 episodes are actually 1 file.
So how can I make the listing look ok, because it will never find the file
Thanks inadvance
there is a setting on sonarr that handles the two part episodes.
mine is like this
Series Name 2x03-04
This will tell sonarr that we have two episodes 03 and 04 but it is only one episode.
Thanks. Where is it I cannot see it.
Also can it recognize that in the listing it say S01e22 and S01e23.
But actually it was broadcast as S01e22-23
not to sure if this is the same…
If you’re searching for the episode try searching for all episodes in the season, as some indexer’s don’t return results properly for multi-episode releases.
If the file is already on disk name it in a way that both episodes are in the filename, if you go to media management settings you can see some of the naming conventions that Sonarr will handle for multi-episode filenames.
