First installation and have some problems
Sonarr version (exact version): 2.0.0.4230
OS: Win 10
Description of issue: First not moving then some issues
first time installing sonnar hope i can get some help
backgroun of the problem: im using transmission is running of a asus router (dont know if this could be the issue) i was first having issues with remote path this was the error:
other information
/ running sonar as a service
/ Use Hardlinks instead of Copy no
/ Completed Download Handling Enable yes/ remove no
/ no using drone factory drone factory interval set 0
“Request Failed: value [/mnt/A/Transmission/XXXXXXXXXX is not a valid Windows path. paths must be a full path eg. C:\Windows”
after that i have corrected the the remote path to the follow:
host:192.168.1.1
remote path /mnt/A/Transmission
local path D:\TV Shows\
now i get another problem and while sonarr send the link to transmission now is not moving this are the issues i am having:
“No files found are eligible for import in D:\TV Shows”
“Import failed, path does not exist or is not accessible by Sonarr: D:\TV Shows\Preacher.S01E10.PROPER.HDTV.x264-KILLERS[rarbg]
Close”
here is the logs
debug : http://hastebin.com/bukafocize.tex
text : http://hastebin.com/iteqodamin.mel
I just responded to your other post, but I’ll say it here for clarity.
The local path you use needs to be pointed at the remote path (SMB share in your case probably), you don’t tell it where to move the files you did that when you added the series to Sonarr.
Thanks for the respond well when i tried to put the path i try this “\\ASUSSMB\Transmission” and it says Path does not exist
again with another response, first thanks for pointing me in the right direction.( will donate to your cause guys) i gave permission under my router to my local username and also edit the services logon website it worked perfect, once again thanks for pointing in the right direction
