Filter Searches?
Sorry if this is posted somewhere, But I can’t find it.
I am a new user, my indexer usually has 4 or so of the file as it searches. One of them is it’s own file the rest are pulled from other places. What happens often is it pulls the other files not the one with the indexers tag on it.
Is there a way to apply a filter for instance
Release-name
Release-name
Release-name
Release-name-indexertag
Filter having “indexertag” in it making Drone pull that file ignore the other three?
Thanks in advance.
(I know you can filter out words, ignores…but I guess I want the opposite…I want the opposite…probably not doable, future feature maybe?)
Not yet, but its something we’ll be adding in a future version (No ETA).
Awesome, I am just fixing those manually for now then.
Just trying to figure out how quality works now. I have many shows that are 720p and I have Cutoff set at 1080p. Do I have to force Drone to rescan those to find better quality files?
I know it will monitor feeds and any NEW posts of better quality releases will be downloaded but in my instance I had some 720p shows already and I imported them in. Now there are 1080p releases already available (not in upcoming feeds but preexisting) so will Drone still search out those? It doesn’t seem to do so unless of course I hit the search button to force it to check.
Thanks again…been trying to figure this out for a bit now…I’ve got a grasp on things just not quite sure on this one.
(I know they’re in the cutoff unmet section…but just don’t know if that section is automatically checked at some point or only checked by monitor new releases)
Missing or Quality not met fall under the same rules: https://github.com/NzbDrone/NzbDrone/wiki/FAQ#how-does-nzbdrone-find-episodes
+1 for me!
Is it not possible to choose a search-resultat with “swesub” for instance, or “DIMENSION” release?
Would be awesome it that would be possible!
/Nicke
Do a manual search and choose whatever you want. Currently its not possible to force that via RSS or automatic searches.
