Hello Sonarr Team,
if not already a feature (somewhere in settings?) is it possible to switch to TVMaze instead of TheTVDB? I find that TVMaze is more accurate with upcoming shows.
On the “Add Series”
http://localhost:8989/addseries
When you search a show it’s default added by the data of thetvdb.com from what I’m seeing.
If you search “The Jeremy Kyle Show” (example) you will see that thetvdb.com is not even updated, it’s years apart from what TVMaze has.
TVMaze has up to date for this show as you can see below:
TVMaze the-jeremy-kyle-show
