Sonarr version (3.0.1.449):
OS windows 10 arabic 64bit: :
https://app.box.com/s/ji3lqcsu2g4eyhs96csl9pb8mj888hfi:
i can’t add any new series! everytime i try to add new series i get erorr (Failed to load search results, please try again.)**:
Thanks for the info, I’ll push up a small fix for this that will hopefully help with the date differences between what skyhook presents and your system expects, I’m not sure if this will be the only spot things are going to go awry though.
thank you mate you are awesome that fix it and now work perfectly, and thank you again for the quick fix
