Hello everybody,
I installed Sonarr today and everything works as it should. Almost everything!
I installed qbittorrent and activated the web interface. The test in Sonarr is OK.
Jacket works so far and the tests are OK there too.
When scanning a series where I checked the torrent, nothing happens.
Does anyone have any input on what could be the error?
I have the following versions:
Sonarr: 3.0.6.1201
.NET: 4.8
Windows 10 Home 64bit
qbittorrent: 4.3.4.1
Jacket version v0.17.830
Firewall is in the VM deactivated
The logs are here:
Debug Logs
21-4-2 15:40:49.1|Warn|SonarrErrorPipeline|Invalid request Validation failed:
– Host: Unable to connect to qBittorrent
21-4-2 15:41:08.2|Warn|DownloadMonitoringService|Unable to retrieve queue and history items from Client qbittorrent
[v3.0.6.1201] NzbDrone.Core.Download.Clients.DownloadClientException: Failed to connect to qBittorrent, check your settings. —> System.Net.WebException: Die Verbindung mit dem Remoteserver kann nicht hergestellt werden. —> System.Net.Sockets.SocketException: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:8080
bei System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
bei System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
— Ende der internen Ausnahmestapelüberwachung —
bei System.Net.HttpWebRequest.GetResponse()
bei NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:Zeile 111.
bei NzbDrone.Common.Http.HttpClient.ExecuteRequest(HttpRequest request, CookieContainer cookieContainer) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:Zeile 126.
bei NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:Zeile 59.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxyV2.IsApiSupported(QBittorrentSettings settings) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxyV2.cs:Zeile 36.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxyV2.IsApiSupported(QBittorrentSettings settings) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxyV2.cs:Zeile 63.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxySelector.FetchProxy(QBittorrentSettings settings) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxySelector.cs:Zeile 87.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxySelector.<>c__DisplayClass7_0.b__0() in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxySelector.cs:Zeile 82.
bei NzbDrone.Common.Cache.Cached1.Get(String key, Func
1 function, Nullable`1 lifeTime) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Cache\Cached.cs:Zeile 104.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxySelector.GetProxyCache(QBittorrentSettings settings, Boolean force) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxySelector.cs:Zeile 82.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxySelector.GetProxy(QBittorrentSettings settings, Boolean force) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxySelector.cs:Zeile 65.
bei NzbDrone.Core.Download.Clients.QBittorrent.QBittorrent.GetItems() in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrent.cs:Zeile 217.
bei NzbDrone
