Sonarr version (exact version): 3.0.3.911
Mono version (if Sonarr is not running on Windows):6.10.0.104
OS: Linux raspberrypi 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
Description of issue: Receive the following message when attempting to connect to Transmission: Failed to authenticate with Transmission.
When I try to add Transmission as a downloader in Sonarr and test the connection, I get an authentication failed error.
The error is located at the level of the identifier.
Detail under Sonarr:
NzbDrone.Core.Download.Clients.DownloadClientAuthenticationException: Failed to authenticate with Transmission.
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.AuthenticateClient (NzbDrone.Common.Http.HttpRequestBuilder requestBuilder, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings, System.Boolean reauthenticate) [0x000b9] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:237
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x0001f] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:256
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetSessionVariables (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:143
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetConfig (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:117
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetClientVersion (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:109
at NzbDrone.Core.Download.Clients.Transmission.Transmission.ValidateVersion () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\Transmission.cs:28
at NzbDrone.Core.Download.Clients.Transmission.TransmissionBase.TestConnection () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionBase.cs:236
Any ideas on what I could be missing here?
