Exclude 480p from SD downloads
Ive just moved from Sickbeard to Sonarr and i’m trying to figure out how to get downloads working the way i like.
I’ve setup my show to download in ‘SD’ quality, but i’m getting a mix of Low quality 480p downloads (180mb) and ‘normal’ HDTV rips (320mb). How can i exclude the 480p from being downloaded?
I’ve removed the ‘WEBDL-480p’ from the profile, but it still downloads 480p (filename of download doesnt contain ‘WEBDL’).
I would rather not increase the minimum size limit for SD incase the ‘normal’ HDTV SD rips are smaller than normal (or 480p rip is larger).
There seems to be a ‘must not contain’ restriction filter for indexers, but i don’t really want to apply a filter at that level, would rather have it on the quality or profile settings, is this possible?
Thanks.
Release restrictions are the only way to reject a release based on something it contains or doesn’t contain, but they will apply to all downloads or at least all downloads for series with the same tags.
under settings - indexer - restrictions i added 480 to must not contain, that was it doenst pick up the 480 releases
