Sonarr version (exact version): 2.0.0.4230
Mono version (if Sonarr is not running on Windows): 4.4.2 (Stable 4.4.2.11/f72fe45 Fri Jul 29 09:58:49 UTC 2016
OS: Debian 8
Description of issue: After upgrading NZBGet to v17.0 I get the errors in the log, any ideas on how to fix it?
Unable to retrieve queue and history items from NZBGet: Cannot access a disposed object.
Object name: 'System.Net.Sockets.NetworkStream'.
System.ObjectDisposedException: Cannot access a disposed object.
at System.Net.WebConnectionStream.EndWrite (IAsyncResult r) <0x40e241e0 + 0x0039f> in <filename unknown>:0
at System.Net.WebConnectionStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) <0x40e22940 + 0x000bb> in <filename unknown>:0
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x000ca] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:51
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0003c] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:33
